Programming flash of TC377TP
EdSi_1398431
I have to develop tool for programming flash of TC377TP using JTAG interface.
In order to implement this I need the following:
1. Document which describes connection to device via JTAG
2. Document which describes registers required for flash programming (erase and program)
Please your assistance.
Aiswarya_A
25 likes received 250 sign-ins 50 solutions authored
1. You could refer to section "1.3 On-Chip Debug Support (OCDS)" in the AURIXTC3XX_um_part1_v2.0 UM.
2. You could refer to the ADS based code example below :
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/Flash_Programming_1_KIT_TC...
https://www.infineon.com/dgdl/Infineon-Flash_Programming_1_KIT_TC375_LK-Training-v01_00-EN.pdf?fileI...
Kind Regards,
Aiswarya.
Aiswarya_A
Kind Regards,
Aiswarya.
