AURIX™ Forum Discussions
User13554
I am using Tricore TC277 D starter kit.To test the board, I am using helloworld example project provided by hightec tool.
When I flash this program on board with simple LED toggle program, it doesnt work.May i know How to check if the root cause of the problem
User13554
I figured out that the source code for led toggle from hightec had a problem.
Manually writing into pins 33.6 to 33.13 works fine.
