Aug 31, 2022
02:05 AM
Aug 31, 2022
02:05 AM
Compiler High-tech.
In Aurix Development Studio i use external GCC conf, just for exercise i'm trying to integrate Unity test framework as external library compiled for Tricore in an other envirement by me as third-parts. How i can do that? It sims is not able to find reference from header file. This is strange i have configured this in building project option. Merci an'avance.
05:28 AM
Aug 31, 2022
05:28 AM
Could you check if the following threads address your question?
Best Regards.
Sep 01, 2022
01:19 AM
Sep 01, 2022
01:19 AM
I had already seen these Topics before writing to you.
I'm sure the library works because I was able to link it in an "old Style" (handwritten makefile) way.
It seems a problem with how the Aurix program constructs the command for the link or missed configuration field.
