Feb 14, 2023
10:56 PM
Feb 14, 2023
10:56 PM
Our requirement is to implement 4 PWMs. 2 are complementary and 1 is phase shifted. Kindly guide how it can be done in TC377.
Intent is to have a dynamically calculated phase shift between 2 PWMs. All other requirements remaining same (complementary PWM's and dead band).
Thank you
01:42 AM
Feb 16, 2023
01:42 AM
Could you check the solution in the following link?
https://community.infineon.com/t5/AURIX/Phase-shift-issue/td-p/366583
01:42 AM
Feb 16, 2023
01:42 AM
