Apr 22, 2020
10:40 AM
Apr 22, 2020
10:40 AM
Some performance tests using Triboard TC275 and Tasking C Compiler with optimization level=3, speed
showed the following results:
1. Addition of 2 int variables
a) defined as local inside a function: 1 cycle (as expected)
b) defined as global outside a function: 18 cycles ???
2. Addition of 2 float variables
a) defined as local inside a function: 2 cycles (as expected)
Global variables are defined with __near memory qualifier to simplify assembler code.
Behavior on Cpu0 and Cpu1 is identical.
Can anyone explain this strong performance degradation using globals?
For my application I am forced to use some globals to keep static data, but I am not allowed to waste some time/cycles.
Apr 22, 2020
11:10 AM
Apr 22, 2020
11:10 AM
Without seeing the assembly code, it's hard to say. My guess is that for the local case, the compiler is assigning your local variables to registers. Less instructions, more speed.
For the global case, it also matters where the variables are stored. Storing a variable in local DSPR takes 0 wait states. Storing a variable in LMU RAM has to go across the SRI bus, but it could be that the CPU Store Buffers absorb the impact without causing a stall.
Share a bit of the disassembly and I can give a better response 🙂
Apr 24, 2020
03:42 AM
Apr 24, 2020
03:42 AM
Thank you very much for the fast response. My first reply seems to be lost. Another turn.
Here the version with local integers:
64 lC=lA+lB
000000008000211a add d2, d4, d5
You are right. Everything is done with registers.
Now the version with global integers:
80 gC=gA+gB;
00000000800020f6 ld.w d15, gA (0x60000000)
00000000800020fa ld.w d1, gB (0x60000004)
00000000800020fe add d15, d1
0000000080002000 st.w gC (0x60000008), d15
Assembly code also looks as expected. Some instructions more but not so much cycles.
I am confused about the addresses of global variables, which are in the DSPR of Cpu1.
I used Cpu0. Have you any hint?
64 lC=lA+lB
80 gC=gA+gB;
Apr 24, 2020
06:11 AM
Apr 24, 2020
06:11 AM
Not so surprising then - those accesses have to go across the SRI bus, which will add a few more cycles when the store buffers are all busy.
Where variables go is dictated by the linker. Tasking gives you a very quick cheat you can use to avoid the relatively difficult linker syntax. Use __at( address ) to specify where a variable is located in the C file:
Give that a try, but eventually you'll need to figure out how to declare LSL sections and addresses to get the best performance. You can steal many such examples from the iLLD files and demos.
unsigned long myvar __at(0x70001000);
Apr 27, 2020
04:29 AM
Apr 27, 2020
04:29 AM
Thank you very much. That works very fine!!! Now all cycles are as expected.
I have only a small number of global variables. Thus this workaround will be good for now.
To be prepared for the future. Can you please tell me, where to find the iLLD files and demos?
Apr 27, 2020
05:39 AM
Apr 27, 2020
05:39 AM
Excellent news 🙂
The iLLD files are available on MyICP. The latest is 1.0.1.11.0:
https://myicp.infineon.com/sites/microcontrollers-aurix_customer_doc/Lists/MyICP%20Customer%20Docume...
If you need access to MyICP, follow the steps here:
https://www.infineon.com/dgdl/Infineon-Customer_+instruction_guide_for_myICP_version_2-ATI-v02_00-EN...
