AURIX™ Forum Discussions
User16819
Hi all,
Performance Counter Registers on TC297 board works only with connected usb cable on board (i suppose,it is debug mode).
_mtcr(CPU_M1CNT,0);
_mtcr(CPU_M2CNT,0);
_mtcr(CPU_M3CNT,0);
_mtcr(CPU_CCNT,0);
_mtcr(CPU_CCTRL,0|(1<<1)|(2<<2)|(2<<5)|(2<<8));
unsigned int value=_mfcr(CPU_CCNT);
but if i connect power supplier, value is null.
what other register i should configurete for connect without USB cable?
Thank you
NeMa_4793301
Level 6
Level 6
Hi Rombic. Try enabling the On-Chip Debug System with this sequence first:
#include "IfxCbs_reg.h"
// Unlock debug system if it's not already unlocked
if( !(__mfcr(CPU_DBGSR) & 0x1) )
CBS_OEC.U = 0xA1;
CBS_OEC.U = 0x5E;
CBS_OEC.U = 0xA1;
CBS_OEC.U = 0x5E;
_mtcr( CPU_DBGSR, 1 ); // enable the Core Debug Controller
User16819
Hi UC_wrangler,
It works! Thank you.
