Equip yourself to optimize AURIX™ MCUs for Evs at the EV Webinar. Click here to register.
AURIX™ Forum Discussions
User18233
If I use a single ATOM channel for PWM generation in TC387 microcontroller, can i use it for ADC triggering & external sensor supply as well. Can this single PWM serve these 2 purposes(Port & ADC)? If yes, then how will it be routed from
ATOM to PORT & ADC modules and can I use a normal PWM for sensor & shifted PWM (from the same single PWM waveform) for ADC?
Thanks in advance!
MoD
25 likes received 50 solutions authored 100 sign-ins
Yes, you can do this. Please have a look in UM vol 2 chapter 26.25.9 and in the UM Appendix TC38X chapter 26.3.9 for connections between GTM and EVADC.
