ThienBui
10 replies posted 5 likes given 10 questions asked
Hi all,
In the attached figure is the description of PSW register of C167xx family chip. The last 3 bits contain the value of ILVL for Global Interrupt while there is a big difference in PSW regsiter of TC234 AURIX TriCore. I've known that the bit IEN in PSW(C167) is equivalent to bit IE in ICR(TC234). However, doese TC234 chip has something that is equivalent to bits ILVL in PSW of C167 chip?
Thien
Prudhvi_E
250 replies posted 100 solutions authored 25 likes received
To know about the Current CPU Priority Number, please refer to the ICR.CCPN bit.
To configure the priority for each interrupt, please do it using SRC.SRPN bit. Hope this helps.
Prudhvi.
Prudhvi_E
Prudhvi.
Hallo, I think I get it now, thank you!
