AURIX™ Forum Discussions
Teoman
5 questions asked 10 replies posted 10 sign-ins
I read that PINA Activation depends on the Vext supply at Standby entry. I need wake up the system by using PINA rising edge trigger input pin. There are several problems. First of all, I make the settings from EB  Tresos. I select pin 14.1(PINA) as input and pull down but when cpu is in Standby mode, I measure 5V from the pin. I set PMSWCR0.xEDCON, xDFEN & xWKEN bits from tresos. I believe that the problem is Vext Supply for Standby Entry. How can I set the Vext Supply and what can be the possible problems?
I also tried to falling edge trigger because PINA pin shows 5V. Even though winIDEA detect the EDCON register pin there is no change in status.
Nambi
250 replies posted First like given 25 likes received
As this is part of MC-ISAR, which is licensed, this topic cannot be discussed in a public forum. We request you to please get in touch with your local Infineon, distributor, or software reseller contact.
Best Regards.
Nambi
Best Regards.
