May 09, 2021
09:12 AM
May 09, 2021
09:12 AM
I have a range of addresses in PFlash (e.g: A0660000-A066FFFF), and only some part of it from the beginning has written data on it. The rest of the pages are erased. I would like to check the address range which contains valid data. Is there an easy way to do that?
I already have a Pmu_VerifyErase function for DFlash that checks if data and ECC bits are all zero, since Dflash can be read at erased state without ECC trap fails. How can I do the same with PFLash sectors without getting ECC fails?
May 09, 2021
10:17 AM
May 09, 2021
10:17 AM
TC2xx or TC3xx?
May 09, 2021
10:48 AM
May 09, 2021
10:48 AM
Sorry, it's TC297
May 09, 2021
11:06 AM
May 09, 2021
11:06 AM
Example program:
* \file TC23x_PFLASH_erase_check.c
* \description Demo code to use the flash program interface to check if a PFLASH word line is erased
* \copyright Copyright (C) Infineon Technologies AG 2021
* Use of this file is subject to the terms of use agreed between (i) you or
* the company in which ordinary course of business you are acting and (ii)
* Infineon Technologies AG or its licensees. If and as long as no such terms
* of use are agreed, use of this file is subject to following:
* Boost Software License - Version 1.0 - August 17th, 2003
* Permission is hereby granted, free of charge, to any person or organization
* obtaining a copy of the software and accompanying documentation covered by
* this license (the "Software") to use, reproduce, display, distribute,
* execute, and transmit the Software, and to prepare derivative works of the
* Software, and to permit third-parties to whom the Software is furnished to
* do so, all subject to the following:
* The copyright notices in the Software and this entire statement, including
* the above license grant, this restriction and the following disclaimer,
* must be included in all copies of the Software, in whole or in part, and
* all derivative works of the Software, unless such copies or derivative
* works are solely in the form of machine-executable object code generated
* by a source language processor.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT
* SHALL THE COPYRIGHT HOLDERS OR ANYONE DISTRIBUTING THE SOFTWARE BE LIABLE
* FOR ANY DAMAGES OR OTHER LIABILITY, WHETHER IN CONTRACT, TORT OR OTHERWISE,
* ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
* OTHER DEALINGS IN THE SOFTWARE.
#include "IfxFlash_reg.h"
#include "IfxScu_reg.h"
#include "stdint.h"
#include "stdbool.h"
bool flash_erased( uint32_t test_address );
volatile uint32_t nonzero_bits;
volatile uint8_t test_blank;
#define FLASH_USER_MARGIN_READ (3U)
// For the ContentVerify we need to calculate
// a) the "base address", which is a multiple of 256kByte
// b) the according WL number
// For that we need following two values for the calculation
#define FLASH_VERIFY_CONTENT_SECTOR_SIZE 0x40000 // 256kByte according to ITS
#define FLASH_WORDLINE_SIZE 0x200 // 512 Bytes
#define FLASH_SEQ1 ((*(volatile uint32_t *) 0xAF00AA50u))
#define FLASH_SEQ2 ((*(volatile uint32_t *) 0xAF00AA58u))
#define FLASH_SEQ3 ((*(volatile uint32_t *) 0xAF00AAA8u))
void main( void )
test_blank = flash_erased( 0xA0000000 );
test_blank = flash_erased( 0xA0000400 );
test_blank = flash_erased( 0xA0000800 );
test_blank = flash_erased( 0xA0100000 );
test_blank = flash_erased( 0xA01F0400 );
for( ;; )
uint32_t wordline_number;
uint32_t base_address;
volatile uint32_t comm1=0;
volatile uint32_t comm2;
uint32_t ucode;
uint32_t testmode_var;
uint32_t current;
uint32_t comm2_bit14_to_bit10_var;
uint32_t wordline_number_comm1_var;
uint32_t wordline_number_comm2_var;
uint32_t comm1_status;
uint32_t comm2_status;
// Wordline and Base Address calculation
// Test is performed on WL number, within a multiple of 256kByte memory range
wordline_number = (test_address % FLASH_VERIFY_CONTENT_SECTOR_SIZE) / FLASH_WORDLINE_SIZE;// Calculates the WL number, which is
base_address = (test_address/FLASH_VERIFY_CONTENT_SECTOR_SIZE) * FLASH_VERIFY_CONTENT_SECTOR_SIZE; //Calculate the base address, which is a multiple of 256kByte
// The User Margin Read function requires a current parameter,
// depending on AURIX firmware version
ucode = SCU_CHIPID.B.UCODE;
if( ucode >= 0x20 )
// In UCODE >= 0x20, the current parameter should be 0.
current = 0;
else if( (ucode >= 0x10) && (ucode <= 0x14) )
// In versions 0x10 to 0x14, the current should be 5.
current = 5;
else
// Older UCODE versions don't support User Margin Read
return false;
// Prepare arguments, shift to needed position
testmode_var = (0x00000003 & FLASH_USER_MARGIN_READ)<<8; // prepared Command test mode
comm2_bit14_to_bit10_var = (0x0000001F & current)<<10; // prepare "reference current" or "control gate voltage" arguments
wordline_number_comm2_var = (0x00000001 & wordline_number) << 15; // Wordline-number bit[0] which is located in COMM2 Register
wordline_number_comm1_var = (0x000001FE & wordline_number) << 7; // Wordline-number bit[8:1] which is located in COMM1 Register
// Write arguments to COMM registers
FLASH0_COMM2.U = wordline_number_comm2_var | comm2_bit14_to_bit10_var | testmode_var;
FLASH0_COMM1.U = wordline_number_comm1_var;
// Read registers to make sure store buffers have been flushed
// before starting FLASH command.
comm2 = FLASH0_COMM2.U;
comm1 = FLASH0_COMM1.U;
comm1 += comm2;
// Clear flash status
FLASH0_FSR.U = 0xFA;
// Start FLASH Command Sequence
FLASH_SEQ1 = base_address;
FLASH_SEQ2 = 1; // verify 1 512 byte word line (sector)
FLASH_SEQ3 = 0x80;
FLASH_SEQ3 = 0x5F;
// Wait the required minimum 23us
// - if this isn't long enough, you'll get a bus error accessing FLASH0_COMM1
//wait_x_10ns(2400); //wait 23us + 1 us;
volatile uint32_t i;
for( i=0; i<2000; i++ ) // 148 works at 100 MHz internal oscillator clock
// Collect the Results from the COMMx Register
// - The result is returned as 13-bit unsigned integer with bits 7:0 in COMM1.STATUS
// and bits 12:8 in COMM2.STATUS bits 4:0
comm1_status = FLASH0_COMM1.U & 0x000000FF;
comm2_status = FLASH0_COMM2.U & 0x0000001F;
nonzero_bits = ((comm2_status & 0x1F) << 😎 | comm1_status;
// The word line is erased if the count of non-zero bits is <= 2
return( nonzero_bits <= 2 );
May 10, 2021
05:12 AM
May 10, 2021
05:12 AM
Hello Support,
This code is part of which software bundle release from Infineon?
Is it part of iLLD or MCAL release?
Best Regards
Best Regards
May 10, 2021
06:38 AM
May 10, 2021
06:38 AM
This example code is not part of a software bundle.
May 10, 2021
07:22 AM
May 10, 2021
07:22 AM
Hello Support,
Can you please provide similar function for TC38x device?
Best Regards
Best Regards
May 14, 2023
05:48 PM
May 14, 2023
05:48 PM
Use the EVER bit in the DMU Error Register for the TC3X to test for successful erasure after calling IfxFlash_eraseVerifySector on the sector under scrutiny.
