AURIX™ Forum Discussions
FD_aurix
100 sign-ins 100 replies posted 5 solutions authored
Hi All
I've seen some reference to this additional core present into Aurix but I can't find more details. Where can I get more information?
thanks in advance
cwunder
If you are referring to the PCP this is the Peripheral Control Processor that is NOT available on AURIX. The PCP was available on prior generations like AUDO Max and AUDO Future as examples. With AURIX you have homogenous multicore capabilities so the PCP was exchanged for this. There can be other cores available on AURIX albeit you have to check that particular device. It could be the HSM, Standby Controller (SCR) or the Multi-Channel Sequencer (MCS) in the GTM as examples.
FD_aurix
ah, this make sense!!. I've found some reference about PCP on the compiler documentation. the compiler works both for AUDOMAX and AURIX.
thanks for the answer!!:)
