ssk
Hello all,
I'm trying to fetch a signal which is a string in nature using Java script. When I use .value to fetch the value it is returning 0 even if the signal value is provided and it is verified using the signal tree.
Added the section of the code used. Any support will be appreciated.
//Inputbuffer is the Char signal created in oneeye
var LocalVar=new JsSignal("Inputbuffer");
dataArray= LocalVar.value;
oneeye.log(dataArray);
Jeremy_Z
250 sign-ins 100 likes received 750 replies posted
Hi @ssk ,
Thanks for your reply.
In my opinion, the issue may be related to the OneEye Configuration file.
Firstly, I'd highly recommend you open a OneEye Configuration file prior to editing the script, next, it provides some OneEye demos for you to refer to and further develop.
BR,
Jeremy
Jeremy_Z
Hi @ssk ,
Please try the below code to retrieve the current value of the signal.
var LocalVar = new JsSignal("Inputbuffer");
var dataArray = LocalVar.getValue();
BR,
Jeremy
ssk
Hello Jeremy,
Thanks for the quick reply. I'm getting a error stating getValue is not a function.
"TypeError: Property 'getValue' of object JsSignal(0x176295f0) is not a function"
Siva
Jeremy_Z
Hi @ssk ,
Whether you ever try to get the value of a float or int variable via the above code, I guess it's related to the string type.
BR,
Jeremy
ssk
Hello Jeremy,
I have declare the signal as Char, and the data entered is shown in the image below.
Let me know if I made any mistake.
Siva
Jeremy_Z
Hi @ssk ,
BR,
Jeremy
