Harris_Fang
5 replies posted 10 sign-ins First like given
Recently, I am operating  HybridKit Drive Sense (logic board ver 4.3) with OneEye(Ver 2.56.0) software, but when I followed the OneEye user manual(as the picture shows) to configure the parameter. I found out that I can't find the configuration file as the second picture shows, does this means I need to create the file by myself ?
And also I found there is a chapter names " Loading a configuration file" in the user manual, now I wonder that the filename "main.OneEye" is the one I need, can anybody help me to solve this problem ?
Hi Fang,
the oneeye files you need are in a subdirectory of the installation directory of the hybridkit.
for an example see the attached png.
Di_W
Hi Fang, Can you try to search *.oneeye in root directory?
Hi DW, Do you mean I can find  a file(xxx.oneeye) contain the configuration that I need ?
Unfortunately, I can't find any configuration file with the function I need. The thing I can see are some files call "tutorial".
Can I find somewhere to download the file which can use for operating HybridKit ?
Di_W
Yes, the tutorials have the only basic .oneeye. For what you needed, I will ask for this.
Hi Fang,
Hi EnglerP, thanks for the reply.
But now the problems is, I don't have the file in the picture from my sbudirectory, so I want to know how can I get the file.
EnglerP
5 replies posted 10 sign-ins 5 sign-ins
Hi Fang,
looking at the first screenshot of your first post I assume that you have the HybridKIT Software Version 2.6.xx installed. This screenshot comes from the pdf "AN-HKIT-ONEEYE.pdf", this pdf resides in the subdirectory "doc\OperationManual" of your HybridKIT Software Installation directory. And when you go 2 directories up from "doc\OperationManual" you will find a subdirectory "oneEye" with the OneEye configuration files.
Hi EnglerP,
Here is the screenshot of my directory, as you can see the pdf "AN-HKIT-ONEEYE.pdf" resides in the "Appnotes" folder, and I also look for the file you mentioned, but I didn't find it.
I just want to know, can I order the file from Infineon ?
Hi Fang,
ok, it seams that we are not talking about the same thing.
Please download and install the HybridKIT Software (V2.6.24) from the Infineon Developer Center (IDC). After installing and starting the HybridKIT Software you will have this oneEye-directory.
Can you please give me you EMail-Address, because I have to give you the rights download the HybridKIT Software V2.6.24 from the IDC.
Hi EnglerP,
Yes sure!
Here is my Email address: itriB20234@itri.org.tw
By the way,I also tried to download the Hybrid Kit software but I couldn't fin.
Can you show me the directory of the Hybrid Kit software, thanks.
Hi Fang,
I now gave you the access rights for the HybridKIT Software in the Infineon Developer Center.
You should now be able to see and download/install it, as shown here:
Peter
Hi Peter,
Thanks for applying the access rights to me, I sucessfully download the HybridKIT Software in the Infineon Developer Center and it works now
By the way, can I ask for another access right to download the Hybrid Kit software, if can, here is the email address : YFJhou@itri.org.tw
EnglerP
Hi Fang,
 YFJhou@itri.org.tw should now also have the access rights.
Bets regards
Peter
