AURIX™ Forum Discussions
User17615
First like received
Hi all,
Can a trap be interrupted by another trap?
Tita
#8042000 21144
User18237
Hi Tita,
yes, it is possible that a trap will be interrupted by other traps, Traps are also assigned priorities that are used when more than one trap occur. You can find the priority order and further details in the TriCore architecture.
Please check
https://www.infineon.com/dgdl/Infineon-TC2xx_Architecture_vol1-UM-v01_00-EN.pdf?fileId=5546d46269bda...
https://www.infineon.com/dgdl/Infineon-TC2xx_Architecture_vol2-UM-v01_00-EN.pdf?fileId=5546d46269bda...
Kind regards,
Mr. AURIX™
