AURIX™ Forum Discussions
User20042
I wonder Multican+ support RX interrupt for each message object that are configured to RX FIFO.
I want to use RX interrupt that triggered when each message object has received a new message.
However I configure MOIPR, MOFCR, INT, and vector table correctly(may be...) but It doesn't work.
Using same configuration except configuring single RX message object (not FIFO), RX interrupt is working.
FIFO overflow interrupt is correctly working for RX FIFO.
I'm using TC275 with SW framework tools.
Thank you for your help.
User20042
It support RX interrupt for RX FIFO.
It's my mistake to configure FIFO slave object.
