AURIX™ Forum Discussions
User20712
[PROBLEM SOLVED]
Hi Admin,
There are two CAN nodes on MULTICAN_1_KIT_TC297_TFT example. First node is used for transmit and second node is used for receive data in loop back mode.
I removed loop back mode on first node and initialized the pins to transmit data to external device, it works properly.
I tried to receive the data by replacing all the initialization code of second node using first node for receiving data, unfortunately it does not work at all.
Is it possible to transmit and receive using one node ? If yes, is there any example or instruction for the configuration ?
Khafizuddin Azazi
[PROBLEM SOLVED]
User20712
This problem has been solved.
LijoDan
10 replies posted First question asked 10 likes given
what was your solution,  i have the same problem, not able to activate the Recieve ISR
UNknown_12
10 sign-ins 5 sign-ins First reply posted
what is the solution, i have facing the same issue
