Hello and Greetings. I am trying to find a Micro-controller for following Requirements.
1. Sensor Integration
2. Flash Memory Enough to Integrate Multiple Sensors.
3.Clock Frequency should be enough to get the real time Data.
4. CAN / Flex-ray / LIN
5. Convert Simulink Models to Embedded code.
Thanks in advance for help
Aurix
You can check out the Aurix Microcontroller. You can also check the Mathworks website on available Simulink support for Aurix.
https://www.infineon.com/cms/en/product/microcontroller/32-bit-tricore-microcontroller/
https://www.infineon.com/cms/en/tools/aurix-tools/SW-Automation_Autocoding/The-MathWorks-Inc/
Best Regards.
Best Regards.
Thanks for the assist..
