Jan 09, 2023
04:13 PM
Jan 09, 2023
04:13 PM
I have been running the following command in CMD to successfully program the MCU by passing a batch file to IMTMemtool.exe with the file to be opened hardcoded in the bat file.
IMTMemtool.exe program.bat
program.bat:
connect
open_file C:\fw.hex
select_all_sections
add_selected_sections
program
disconnect
exit
However, if I try to pass the hex file as a parameter by changing the 2nd line in program.bat to
open_file %1
and use the following command
IMTMemtool.exe program.bat C:\fw.hex
I get the error "Batch execution failed in line 1 !"
How would I pass the hex file as a parameter to the batch file?
