Equip yourself to optimize AURIX™ MCUs for Evs at the EV Webinar. Click here to register.
AURIX™ Forum Discussions
User19909
First like received
Hello, is there a document explaining the difference between memories -LMU-DSPR-PSPR-DLMU and so on- their speed an what is stored in each normally?
Darren_Galpin
DSPR, PSPR and DLMU are all within the CPU and should be described in that chapter of the user manual. The LMU is external to the CPUs and has its own chapter in the manual. There is a table in chapter 2 of the UM which gives access speeds to the different memory types in cycles.
