AURIX™ Forum Discussions
User18983
Hello all,
I am wondering that is there any way to measure/capture individual core usage on uC TC39xx.
One approach I found is calculate the percentage of time the CPU is not in idlle time ( OS awareness is required).
Target device : TC397x.
Debugger : Lauterbach PowerDebug USB with Trace32 PowerView.
Thank you in advance!
Cuong
NeMa_4793301
Level 6
Level 6
Hi Cuong. Each CPU core has performance counters that can be started or stopped at user-definable addresses. The counters measure clocks elapsed, instructions executed, and a few selectable counters (cache misses, cache hits, etc.). Refer to the Core Debug Controller in the TriCore Architecture Manual for details.
