Hi all,
In safetymanual, ESM[SW]:SYS:MCU_FW_CHECK give the value of MTU_FAULTSTS after reset, and software should check it.
The value for SSH0(CPU0_DMEM) is 0x0B in my board, but the given value is 0x09. OPERR[1] is set additionally in my board, It's means " Auto-data-init or Partial erase (caches) was triggered, resulting in overwriting of SRAM", but I don't understand, please tell me the reason and how to deal with it, thank you.
Best Regards
Aurix
- mbist
Please contact the local sales/ FAE team since the safety topic needs an NDA and cannot be discussed in the public forum.
Best Regards.
The result for other modules:
WarmPORST_Val_Expected | WarmPORST_Val_Real | |||||||
SSH_ID | Module | Auto-Init | ECCD | FAULTSTS | ERRINFO[0] | ECCD | FAULTSTS | ERRINFO[0] |
0 | CPU0_DMEM | Y | 5 | 9 | 0 | 5 | 11 | 0 |
1 | CPU0_DTAG | N | 5 | 1 | 0 | 5 | 11 | 0 |
2 | CPU0_PMEM | Y | 5 | 9 | 0 | 5 | 11 | 0 |
3 | CPU0_PTAG | N | 5 | 1 | 0 | 5 | 11 | 0 |
4 | CPU0_DLMU_STBY | Y | 5 | 9 | 0 | 5 | 9 | 0 |
5 | CPU1_DMEM | Y | 5 | 9 | 0 | 5 | 11 | 0 |
6 | CPU1_DTAG | N | 5 | 1 | 0 | 5 | 11 | 0 |
7 | CPU1_PMEM | Y | 5 | 9 | 0 | 5 | 11 | 0 |
8 | CPU1_PTAG | N | 5 | 1 | 0 | 5 | 11 | 0 |
9 | CPU1_DLMU_STBY | Y | 5 | 9 | 0 | 5 | 9 | 0 |
10 | CPU2_DMEM | Y | 5 | 9 | 0 | 5 | 11 | 0 |
11 | CPU2_DTAG | N | 5 | 1 | 0 | 5 | 11 | 0 |
12 | CPU2_PMEM | Y | 5 | 9 | 0 | 5 | 11 | 0 |
13 | CPU2_PTAG | N | 5 | 1 | 0 | 5 | 11 | 0 |
14 | CPU2_DLMU | Y | 5 | 9 | 0 | 5 | 11 | 0 |
34 | CPU0_DMEM1 | N | 5 | 1 | 0 | 5 | 11 | 0 |
35 | CPU1_DMEM1 | N | 5 | 1 | 0 | 5 | 9 | 0 |
38 | DAM0 | N | 5 | 1 | 0 | 5 | 1 | 0 |
41 | SADMA | N | 5 | 1 | 0 | 5 | 1 | 0 |
42 | MINI_MCDS | N | 5 | 1 | 0 | 5 | 1 | 0 |
53 | GTM_FIFO | N | 5 | 1 | 0 | 5 | 1 | 0 |
55 | GTM_MCS0FAST | N | 5 | 1 | 0 | 5 | 1 | 0 |
57 | GTM_MCS1FAST | N | 5 | 1 | 0 | 5 | 1 | 0 |
58 | GTM_DPLL1A | N | 5 | 1 | 0 | 5 | 1 | 0 |
59 | GTM_DPLL1BC | N | 5 | 1 | 0 | 5 | 1 | 0 |
60 | GTM_DPLL2 | N | 5 | 1 | 0 | 5 | 1 | 0 |
62 | M_CAN10 | N | 5 | 1 | 0 | 5 | 1 | 0 |
63 | M_CAN20 | N | 5 | 1 | 0 | 5 | 1 | 0 |
65 | PSI5 | N | 5 | 1 | 0 | 5 | 1 | 0 |
66 | ERAY_OBF0 | N | 5 | 1 | 0 | 5 | 1 | 0 |
68 | ERAY_TBF_IBF0 | N | 5 | 1 | 0 | 5 | 1 | 0 |
70 | ERAY_MBF0 | N | 5 | 1 | 0 | 5 | 1 | 0 |
77 | SCR_XRAM | N | 5 | 1 | 0 | 0 | 9 | 0 |
78 | SCR_RAMINT | N | 5 | 1 | 0 | 0 | 9 | 0 |
82 | GIGETH_RX_RAM | N | 5 | 1 | 0 | 5 | 1 | 0 |
83 | GIGETH_TX_RAM | N | 5 | 1 | 0 | 5 | 1 | 0 |
Hi, IFX
I need help! Thank you
Help me pleeeeeeeeeeeeeeeeeeeeease!
Best Regards
Best Regards.
