Jul 19, 2021
07:04 AM
Jul 19, 2021
07:04 AM
[EV Board TC377 - TASKING IDE 6.3r1 patch4]
I would like to make sure that each CPU can only access its own DSPRx and the entire LMU.
I downloaded the example "expert training - MPU_Memory_Protection_1
for KIT_AURIX_TC397_TFT "
I adapted the example to my EVBoard by modifying the LED ports.
as described, the first led lights up to indicate that it is reading the part of the ram that is authorized and then the second led should not light up because it should go into trap when reading the protected ram.
both LEDs light up for me.
is it possible that my software is running in supervisor mode? (if yes, how can I run the software in user-1 mode?)
