I am trying to trigger MONBIST execution and get the MONBIST results on ( trace 32 Simulator )but it stuck here despite TSTEN is enabled but test doesn't start
Please refer to the ILLD APIs Ifx_Ssw_Monbist(), and Ifx_Ssw_MonbistCheck() for Monbist execution and MONBIST error state check.
Best Regards.
There's not any functions with this name
You can find these APIs as a part of Ifx_Ssw_Infra.c
Best Regards.
How can i include those functions because when include header file of them there are don't appear
The functions are based on the macro "IFX_CFG_SSW_ENABLE_MONBIST" defined in the file Ifx_Cfg_Ssw.h. If you enable it during the startup itself, the test is executed automatically.
Please search for IFX_CFG_SSW_CALLOUT_MONBIST definition and Ifx_Ssw_Monbist function in the ADS project you're using for more details. Either you can enable the macro which is mentioned in the previous paragraph or copy the logic and call it as per you need.
Prudhvi.
