Jan 29, 2021
02:17 AM
Jan 29, 2021
02:17 AM
When I try to validate MCU configuration by using tresos as third party integration in DaVinci configurator tool with MC-ISAR_AS42x_TC3xx_BASIC_1.40.0-rc I get following error:
MCU01803: Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Mcu/McuModuleConfiguration/GtmGlobalConfiguration/GtmGlobalConfiguration/GtmTomGlobalConf/GtmTomGlobalConf/GtmTomChannelConf/GtmTomChannelConf_6/GtmTimerPortPinSelect": (1806) The XPath-expression "ecu:list(concat('Gtm.','Tom',substring-before(substring-after(node:fallback('->node:path(.)','GtmTomGlobalConf_BMD/GtmTomChannelConf'),'GtmTomGlobalConf_'),'/GtmTomChannelConf'),'Channel',substring-before(substring-after(node:fallback('->node:path(.)',''),'GtmTomChannelConf_'),'/GtmTimer'),'ToutSel'))" caused an error: (35010) The requested ECU resource property "Gtm.TomChannel6ToutSel" does not exist
Is it a known issue? Any suggestion for solving this issue?
12:47 AM
Mar 09, 2021
12:47 AM
Did you found the solution for this problem?
