AURIX™ Forum Discussions
User18288
First like received
I integrated the MCAL to Vector tool as third party installation and tried to configure the MCU module. (Note: I was able to generate MCU with the existing project and with the same SIP)
I was facing the below issues. Any suggestions?
Error:
MCU01803 Invalid XPath-expression for Attribute "ENABLE" of node "McuETHDivider": (1806) The XPath-expression "ecu:get('Mcu.fEthExists')='true'" caused an error: (35010) The requested ECU resource property "Mcu.fEthExists" does not exist
ScottW
First solution authored First like received 5 sign-ins
Make sure you are doing your initial configuration in the included TRESOS tool before configuring with DaVinci. There are templates that need to be populated before the configuration files can be used.
User18288
First like received
Hi Scott,
Thank you for the reply. Adding the Resource (Aurix/Resource) module in Vector tool solved the issue. The Resource module just contains the micro variant.
