AURIX™ Forum Discussions
nsyed
50 sign-ins First solution authored 25 sign-ins
Does clearing of CCCR.INIT after a bus-off event is sufficient to recovery the CAN module from bus-off condition ?
Is any other steps needed ?
Can you please clarify ? I am working on the TC377 controller
VincentWan
First like received 25 replies posted 10 replies posted
yes, correct.
User need to clear CCCR.INIT bit to start bus off recovery sequence, it will then wait for 129 occurrences of Bus Idle (129 * 11 consecutive recessive bits) before resuming normal operation.
nsyed
VincentWan wrote:
yes, correct.
Thank you so much!!! Appreciate your help !!!
