I have a question related to MC-ISAR and iLLD.
I see that iLLD has for some module some additional functionality that is not included in the MC-ISAR, for example for the CCU6 in the iLLD there are the PwmHl functions that make it
quite easy to implement PWMs for driving MOSFET for inverters, but there is no such an implementation in MC-ISAR.
In this case, is it possible to take the implementation from iLLD?
Is there any guide for integrating iLLD together with MC-ISAR or how should this be done, as the structure for the iLLD and the MC-ISAR azar is totally different for CCU6 echatspin for example.
Aurix
Hello BettyRNorahDeni,
as of today there is no possibility to migrate iLLD driver to MC-ISAR or similar. iLLD's are more developed with the intention of being used of demo-code. There is no ASIL claim or similar to it.
So you have three options:
- Implement your own Autosar driver for CCU6 based on demo-code of iLLD
- Instead you can try to implement your application using the GTM (A-)Tom's. There is also the possibility to add inverted outputs with dead-time insertion
- Or you can contact one of our software-tooling-partners like e.g. Hitex to let them custom implement it for you.
Markus
Markus
