MBIST test for TC387 from examples.
User22447
First like given 5 replies posted 5 sign-ins
Hello team,
I am using the demo example from https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples here. In MBIST demo example, default MBIST is for DMA. By using ADS compiler, MBIST test is passing correctly. But if used same example for testing the CPU0_DSPR(test_MTU_MBIST(IfxMtu_MbistSel_cpu0Dspr);), it is failing in the highlighted instruction i.e. while enabling the SSH for CPU0. Please let me know the reason befi
Please help me to perform MBIST for different IP in TC387.
Yuva
250 replies posted 250 sign-ins 100 solutions authored
I guess there is access to the CPU0 DPSR/DCACHE during the test, this is a violation. Please refer to details in section 13.3.8.1 of the user manual.
User22447
Yuva
User22447
Yes, I got it. while debugging it will violate. Need to free run the test.
