04-Components\VectorPackage\Supplied\BSW\Tp_Iso10681\FrTp_TxSm.o 04-Components\VectorPackage\Supplied\BSW\Tp_Iso10681\FrTp_Util.o 04-Components\VectorPackage\Supplied\BSW\vOtaM\vOtaM.o 04-Components\VectorPackage\Supplied\BSW\VStdLib\vstdlib.o -lc_fpu -lfp_fpu -lrt "-LC:\app\TASKING\TriCore v6.3r1\ctc\lib/tc162"
Segmentation fault
amk E452: ["makefile" 71/0] target 'RN050524-S1-Bootloader-Mainline.elf' returned exit code 1
amk E451: make stopped
TC36xx: The above error getting while linking. Please suggest me how to resolve this error.
The fault could happen when your program tries to access memory out of bounds i.e. beyond the limits that is allocated for your program. Please check the Linker file regarding size assignment and if there are any array definitions in your code that exceeds the available size.
Also, please check if there are any open issues from your Compiler Vendor that could relate to this issue.
Prudhvi.
