AURIX™ Forum Discussions
dparikh
First solution authored 5 replies posted 5 sign-ins
Hi All,
I am introducing one interrupt for SMU in my project for TASKING compiler.
IFX_INTERRUPT(SMU0_ISR, 0, 0x1)
/* Enable Global Interrupts */
ENABLE();
smu_isr_status = 1;
upon building the file I am getting compilation error as below:
ltc E112: cannot locate 1 section(s):
ltc I455: requirement: 0xa bytes of ROM area in space mpe:vtc:linear
ltc I456: section type: absolute restriction - at address 0xa00f0020
ltc I457: .text.inttab0.intvec.001 (178) (0xa bytes)
ltc I428: binding locator symbols (task1)
ltc I429: evaluating expressions (task1)
Could you please help to resolve the error.
Linker used: tc33x.lsl
Prudhvi
25 likes received 50 solutions authored 250 sign-ins
Prudhvi
Hi dparikh,
I think you may modify as below:
/* ISR declaration. The Macro expands to the assembly code with jump instructions to the function */
/* Function definition */
void SMU0_ISR(void)
  ENABLE();
  smu_isr_status = 1;
Please let us know if this works.
Prudhvi.
Hello @Prudhvi ,
Thank you for the reply, I tried as below but still facing the same error.
void SMU0_ISR(void);
IFX_INTERRUPT(SMU0_ISR, 0, 0x1);
void SMU0_ISR(void)
ENABLE();
smu_isr_status = 1;
Error:
Prudhvi
Hi dparikh,
Could you please share your Linker file?
Prudhvi.
Hi Prudhvi, Please find attached linker zip.
Prudhvi
Hi dparikh,
Let me check the linker meanwhile, please check the below threads if they solve your problem:
https://community.infineon.com/t5/AURIX/Linker-Error-TC277-Tasking/td-p/318527
https://community.infineon.com/t5/AURIX/assigning-a-address-to-a-Global-Constant-in-PFlash-AURIX-TC2...
Prudhvi
