AURIX™ Forum Discussions
SagarZF
First question asked Welcome!
Error:
"C:\\app\\TASKING\\TriCore v6.3r1\\ctc\\bin\\amk" -j12 all
Linking to RN050524-S1-Bootloader-Mainline.elf
ltc F014: core mpe:tc0 specified on commandline not found in LSL file
amk E452: ["makefile" 68/0] target 'RN050524-S1-Bootloader-Mainline.elf' returned exit code 1
amk E451: make stopped
please suggest me how to resolve this error.
User13836
10 likes received 50 sign-ins 10 solutions authored
The information provided indicates that you are using the TASKING TriCore toolset v6.3r1. The linker error message:
is generated when the linker LSL file you are using is for the virtual core definition (vtc) and not for a core 0 only core definition. Please verify the linker invocation options used. I suppose the option
--core=mpe:tc0
is used. If so please replace this by option:
--core=mpe:vtc
to verify if the linker error persists or disappears.
Ulrich Kloidt
TASKING tools support
dw
@User13836 Could you please have a look?
Hi Sagar,
Suggest to start from an original project to build, then check what is changed in your project.
User13836
--core=mpe:tc0
--core=mpe:vtc
Ulrich Kloidt
