LBIST
Jinakot
First question asked Welcome!
I tried to Set SCU_LBISTCTRL0 REGISTER in order Trigger COLD PORST in TC3xx Bellow you can find what I set: PER.Set.simple D:0xF0036164 %Long 0x80000002 PER.Set.simple D:0xF0036164 %Long 0x80000001 After that the CPU was in hard reset state and I couldn't put the CPU in running state. Is there any clarification of this behavior?
Meet_T
25 likes received 50 solutions authored 100 replies posted
HI @Jinakot , Could you please try to run LBIST from start-up by configuring the UCB, or you can trigger LBIST in Application software using LBISTCTRL0 register. Please make sure to do this while the debugger is not connected, kindly refer to SCU_TC.H021 errata as this might be relevant to your query.
Meet_T
