K_SC
First like given First question asked Welcome!
I'm using the labview program.
Is it possible to control the product using the program?
ps.Infineon Memtool 4.6 not used
Di_W
If only to use Labview to communicate with Aurix, you can use UART. If you want to control debug port, you can refer to DAS library but no direct solution. The DAS can recognize the miniWiggler, which can use USB port to simulate a COM port in device driver.
Besides, Infineon has One Eye to replace Labview for GUI programming of Aurix.
Di_W
