AURIX™ Forum Discussions
User14659
Hello All,
I am trying to connect TC27x device with miniwiggler DAP, but i notice the following error
Starting Debugger...
The debug instrument IO could not be initialized.
The GDI debug instrument provided the following error message.
An internal error has occurred.
I have started the UDAS derver using DAS server.
Am i missing something here?
User13290
First solution authored
Hi Abhinand,
abhinand wrote:
Hello All,
The free entry toolchain restricts debugging to the onboard wiggler. So you can only connect to the target via its USB connector.
Henk-Piet Glas
Principal Product Specialist
User14659
Thank you Henk-Piet for your response. The issue was with hardware and i have resolved it.
User13290
Hi Abhinand,
Thanks for letting us know. Good to hear you got it sorted.
Henk-Piet Glas
