Aug 01, 2019
01:18 AM
Aug 01, 2019
01:18 AM
04:40 AM
Aug 01, 2019
04:40 AM
Yes! You can download the TASKING Pin Mapper for AURIX.
Benefits of the TASKING Pin Mapper for AURIX:
The Pin Mapper tool reduces developer time and costs, while improving the quality of results.
Configuration takes place via an intuitive Eclipse based GUI with built-in knowledge about AURIX devices and packages. This saves the developer from the tedious task of consulting piles of Device Manuals and maintaining configuration settings in spreadsheets.
Configuration errors/conflicts are detected at entry time and can be either automatically resolved by the Built-in Conflicts Solver or solved manually. Whereas traditionally such errors remain hidden until code has been generated and is tested.
The Pin Mapper reduces miscommunication between individuals and teams by creating all project files from one source. The Pin Mapper creates:
device initialization code in ISO-C format
a spreadsheet (CVS) file for project documentation
a schematic symbol block that can be imported by PCB design tools such as Altium Designer
https://go.altium.com/pin-mapper-license-request-tasking
