Jan 16, 2020
06:29 AM
Jan 16, 2020
06:29 AM
05:19 AM
Jan 17, 2020
05:19 AM
Hi Lina,
Yes, this is stored in TC2xx devices in UCB_IFX and in TC3xx devices in the UCB_USER. Both provide a 128bit unique ID for each chip. If only chip type should be identified this can be done using the SCU_CHIPID register.
Kind regards,
Mr. AURIX™
Kind regards,
Mr. AURIX™
Jan 21, 2021
08:28 AM
Jan 21, 2021
08:28 AM
Hi all,
Regarding the same question, but for the XMC4500 running under DAVE4.
Is there a unique id i can read from some register?
TIA
Maccabi
TIA
Maccabi
Jan 28, 2021
10:32 AM
Jan 28, 2021
10:32 AM
Maccabi wrote:
Hi all,
TIA
Maccabi
This is not the correct forum for your question...
Anyhow have you reviewed the XMC4500 reference manual section 26.2.2 Initial boot sequence and in particular Figure 26-1 DSRAM1 usage by the SSW where the Unique Chip ID (16 bytes) is written?
