Interrupt configuration for PWM Output using Atom
Dev
10 questions asked 5 replies posted 25 sign-ins
Hello Team,
We are trying to configure ISR for PWM generation using ATOM for 3 channels. We are able to configure for one channel only and other two ATOM channels ISR is not working. Please let me know if you have any idea on the same.
configured ISR below for reference.
IFX_INTERRUPT(ATOM0Ch1_ISR, 0, ATOM0_CH1_PRIO)
Thank you
Nambi
50 likes received 5 likes given 100 solutions authored
Can you share the code snippet used to configure the interrupt and check if the event triggering the interrupt has occurred?
Best Regards.
