This thread is not a question but a hint for the ones who want to establish the SPI communication with the PMIC "TLF",
you can add the Interrupt Handlers in: void initQSPI2Master(void){
IfxCpu_Irq_installInterruptHandler(&masterTxISR, ISR_PRIORITY_MASTER_TX);
IfxCpu_Irq_installInterruptHandler(&masterRxISR, ISR_PRIORITY_MASTER_RX);
IfxCpu_Irq_installInterruptHandler(&masterErISR, ISR_PRIORITY_MASTER_ER);
Code source: SPI_TLF
Hi 21730,
Thank you for your suggestion. However, IfxCpu_Irq_installInterruptHandler() is only used with IFX_USE_SWMANAGED_INT defined. Generally, the demo code has no this macro defined, then the traditional way works.
IFX_INTERRUPT(masterTxISR, 0, ISR_PRIORITY_MASTER_TX); /* SPI Master ISR for transmit data */
IFX_INTERRUPT(masterRxISR, 0, ISR_PRIORITY_MASTER_RX); /* SPI Master ISR for receive data */
IFX_INTERRUPT(masterErISR, 0, ISR_PRIORITY_MASTER_ER); /* SPI Master ISR for error */
dw
Hi 21730,
dw
