I am using Aurix TC397XX uC, I could not find accurate value of the internal Pull Up and Down used. Could you please let me know what the values are?
In the datasheet of TC39x, you can find On-Resistance of pad output RDSON CC
Otherwise, Values for Pull-up resistor is defined via parameter RMDU in table VADC 5V. Values for Pull-down resistor is defined via parameter RMDD in table VADC 5V
My question is regarding the pull up resistors used... In the parameter RDSON CC I could find different resistance values in terms of ohms, but there is weak pull ups and pull downs inside Aurix. I wanted the value of that.
If you check the GPIO 3.3V/5V part from datasheet, you can see the pull-up and pull-down current with footnote 4) of resistors inside the chip.
