I am using Aurix TC397XX uC, I could not find accurate value of the internal Pull Up and Down used. Could you please let me know what the values are?
If you check the GPIO 3.3V/5V part from datasheet, you can see the pull-up and pull-down current with footnote 4) of resistors inside the chip.
In the datasheet of TC39x, you can find On-Resistance of pad output RDSON CC
Otherwise, Values for Pull-up resistor is defined via parameter RMDU in table VADC 5V. Values for Pull-down resistor is defined via parameter RMDD in table VADC 5V
My question is regarding the pull up resistors used... In the parameter RDSON CC I could find different resistance values in terms of ohms, but there is weak pull ups and pull downs inside Aurix. I wanted the value of that.
