Apr 28, 2020
03:42 AM
Apr 28, 2020
03:42 AM
New to AURIX TC3xx, going through the documentation.
I see the DAM module, an apparently new 32-64kb SRAM available at SRI, additional to LMU - have doubt on its intended usage. Posting here in case somebody has some remark on that.
It pretty much resembles LMU, according to what I get from documentation, with the differences:
-DAM is not ASIL-x compliant
Then, provided that, for example in TC397 DAM is actually smaller than LMU (64kb vs 256kb), and actually has more latency (according to table 74 of latencies), I'm wondering: What is the intended usage of the DAM? Wouldn't LMU be more suitable in all cases? (bigger, faster, and ASIL-D).
Also, I wonder in which sense it's non-ASIL-x: Functionally, from doc, is very similar to LMU, including ECC, etc. The non-ASIL-x qualification comes from the way it's been implemented/silicon?
Greetings,
Greetings,
Apr 28, 2020
05:34 AM
Apr 28, 2020
05:34 AM
The DAM is the memory for the Advanced Modeling Unit (AMU), a secretive hardware accelerator described in this paper:
https://www.sae.org/publications/technical-papers/content/2020-01-1366/
If you're not using the AMU, then it's just a bonus blob of RAM your application can use. Generally, the LMU is more suitable for safety-relevant data.
Apr 29, 2020
02:54 AM
Apr 29, 2020
02:54 AM
Thanks for reply and link.
Now clearer - didn't come accross that module/unit.
Do you have any idea on why DAM may not be so suitable for safety? Still a bit puzzled about that as, functionally, LMU & DAM look so similar.
05:04 AM
Apr 29, 2020
05:04 AM
The AMU+DAM are a block of IP that are QM, and thus lack the additional bells and whistles such as ECC monitor logic.
Oct 05, 2020
06:23 AM
Oct 05, 2020
06:23 AM
Hello guys,
Also new to Infineon AURIX.
I saw this post and I'm also interested in the reason why DAM is not ASIL x-comliant.
In the AURIX_TC3xx_UserManual at P. 575 and P. 590, it mentions that the data in DAM and also LMU is protected by ECC.
There are also memory protection and register protection.
The mechanisms of both do look similar.
Are there other factors take a part?
Thank you
Thank you
Oct 05, 2020
09:37 AM
Oct 05, 2020
09:37 AM
Yes - things such as is the entire data path from the RAM to the system interconnect protected. Although the SRAM may indicate that there was an error on the stored data, this does not mean that the data is then protected until it reaches the bus (where it would again be protected).
Nov 13, 2020
12:42 AM
Nov 13, 2020
12:42 AM
Hello Darren,
I see. Thank you for your reply!
Ruby
Ruby
