Apr 07, 2021
08:26 PM
Apr 07, 2021
08:26 PM
I was checking the Memory Maps in the User Manual of TC3xx - V1.3.0, Section#2 MEMMAP V0.1.16. I have below observations, Can you please clarify if these are typo’s or what the correct address range is.
Apr 08, 2021
02:12 AM
Apr 08, 2021
02:12 AM
Hi Nadeem - good spot, and I see the same problem in internal documentation when I checked it. For the SDMMC, please assume that the start of the reserved location is wrong, and for the others, please assume that the reserved location should cover the missing addresses. I have raised an internal issue request to get this fixed - thanks for reporting it.
Apr 08, 2021
10:50 AM
Apr 08, 2021
10:50 AM
Thanks for clarifying. I found AURIX forum very helpful to clarify and address these type of questions. Hope to see these fixes in the future release of User manual.
Apr 08, 2021
04:49 PM
Apr 08, 2021
04:49 PM
Hi Darren,
could you please check this also for TC2XX?
@Nadeem
Very good!
Jens
@Nadeem
Very good!
Jens
Apr 09, 2021
12:48 AM
Apr 09, 2021
12:48 AM
Hi Jens,
Not an issue on TC2XX - the 0xFA addresses are all reserved/SRIBE, the 0xF02 addresses are all SPBE reserved, and the other gap is where the MULTICAN was.
Cheers,
Darren
Cheers,
Darren
Apr 09, 2021
12:55 AM
Apr 09, 2021
12:55 AM
Hi Darren,
perfect 🙂
Jens
perfect 🙂
Jens
