Aug 06, 2022
07:57 AM
Aug 06, 2022
07:57 AM
Hello Community,
If u r reading this thanks for your time.
I Have below issue case:
Case: In RSTSTAT register EVR33 bit is getting SET sporadically after the Warm Reset ?
- Already known things: EVR is regulator which is supplies the PFLASH. In case of the under-voltage or Over-voltage detection this bit is expected to getting set. under-voltage or Over-voltage detection can be done by using the SCU_EVRSTAT register, but in my case there no UVO or OV flag is SET.
Does anybody having the any suggestion, how to debug it further ?
Any idea, hint or clue is appreciated 😊
10:06 PM
Aug 07, 2022
10:06 PM
Could you please share the screenshots of RSTSTAT & EVRSTAT register when the issue occurs? Also, could you please let us know which Microcontroller derivative you are using?
Prudhvi.
Aug 07, 2022
10:14 PM
Aug 07, 2022
10:14 PM
