User17612
First like received
Hi all ,
In term of PWM output generation, what are the differences between ATOM and TOM in GTM module ?
Thanks in advance
Lucas
#8042000 20355
User18237
Level 5
Level 5
First solution authored First like received
Hi Lucas,
Timer Output Module (TOM) offers independent channels to generate simple PWM signal to each output pin based on compare values.
ATOM (ARU-connected TOMs) offers additional functionality to generate complete output signals without CPU interaction due to connectivity to Advanced Routing Unit (ARU).
ARU output signal can be connected to other ARU connection of PSM, MCS or DPLL module.
Kind regards
Mr.AURIX™
