AURIX™ Forum Discussions
User17612
First like received
Hi all,
If TESTMODE pin/ball is opened by any accident, the device will go into testmode?
Kind regards
Lucas
#8042000 20412
Harvey
The default status of TESTMODE pin is pull-up.
So, When TESTMODE pin is opened, generally we can say that there is no problem.
But, this is really important pin for MCU normal booting.
So, In order to guarantee pin status (high) from some noise or other environmental factor, pull-up on TESTMODE pin is required.
Harvey
The default status of TESTMODE pin is pull-up. (It can be checked in data sheet)
1: Normal Mode
0: Test Mode
MoD
250 sign-ins 25 likes received 50 solutions authored
No, device will not go in testmode. The internal pull-up is always active during and after reset unless user software change TESTMODE port register.
