AURIX™ Forum Discussions
UNknown_12
10 sign-ins 5 sign-ins First reply posted
Hi Guys,
How to Configure ISR Interrupt For CPU1 in TC297? Is there  any example code
Please Share me.
You need to have the desired TOS configured in that interrupt SRC_xx register. The guidance from dw above is only for the vector table entry.
/* configure QSPI2 Error interrupt to be serviced by CPU0 */
SRC_QSPI2ERR.U = TOS_CPU0 | SRE_ON  | SRPN_CPU0_QSPI2_ERR;
If you want it to be serviced by CPU1 then:
/* configure QSPI2 Error interrupt to be serviced by CPU1 */
SRC_QSPI2ERR.U = TOS_CPU1 | SRE_ON  | SRPN_CPU0_QSPI2_ERR;
The Interrupt Router TC29x module provides multiple groups of General Purpose Service Requests (GPSR) and a mechanism to trigger multiple Service Requests of a GPSR group in parallel, by software. The GPSR can be used as Software Interrupt.
dw
IFX_INTERRUPT(isrSTM, 0, ISR_PRIORITY_STM);
/*here 0 is CPU0, and 1 would be CPU1, and so on... */
Dear Users,
About ISR related to CPU0/1/2, I have checked the demo code of TC2XX, and found above code sample for your reference. The notice is that 0/1/2 represents CPU0/1/2.
dw
UNknown_12
Actually I tried i changed vector table 0 to 1, but interrupt is not going.  It is possible to give vector table 1 in  TC297
Because TC297 Architecture is totally different. it seems interrupt module is for only cpu0 but we can give different priority. This all are my analysis .
My question is In TC297 it is possible to give parallel interrupt and will it service to cpu0 and cpu1 parallel?
dw
Dear user,
I have send an email to you. The register settting is like above cwunder showed already. Another way is to use C function as below:
    IfxSrc_init(src, IfxSrc_Tos_cpu0, ISR_PRIORITY_GPT12_T2_INT);
      /* Highest priority */
    IfxSrc_enable(src);
dw
