AURIX™ Forum Discussions
User17740
First like received
Hi all,
Is I2C hardware module available in AURIX™ ?
Kind regards
Bernie
#8042000 12643
teoBits
100 replies posted 50 replies posted 25 replies posted
Hello Bernie,
Yes, AURIX™ devices support I2C, you can find a quick guide on the module here: https://www.infineon.com/dgdl/Infineon-AURIX_Inter-Integrated_Circuit_Module-Training-v01_00-EN.pdf?...
Furthermore, if you are interested on how to use the module, you can find a code example project that uses the module here: https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/I2C_Read_Ext_Device_1
this example also comes with a tutorial, which can be found here: https://www.infineon.com/aurix-expert-training/Infineon-AURIX_I2C_Read_Ext_Device_1-TR-v01_00_00-EN....
If you are interested in other modules and you want to start programming for AURIX™, you can get the AURIX™ Development Studio here: www.infineon.com/aurixdevelopmentstudio and get inspired by numerous Trainings from www.infineon.com/aurix-expert-training
Hope it helps,
teoBits
