I2C repeated start with TC377
samcs
5 likes given 10 questions asked 25 sign-ins
Hi ,
I am using  Ifx_Tc3xx_I2c package, the CPU is TC377, the I2C device needs a Read format as follows:
S,Slave Addr+0,Ack(slave), Regisger address, Ack, ReStart, Slave Addr+1, Data1,Ack, Data2,Ack,...,
In I2c.c in the folder, there are I2c_AyncWrite(), I2c_SyncWrite(), I2c_AyncRead(), I2c_SyncRead() APIs.
Could anyone show me how to generate the repeated start or provide the sample code.
Nambi
50 likes received 5 likes given 100 solutions authored
Wangbk
25 sign-ins 10 replies posted First question asked
Is the waveform you want like the one shown in the picture below? There is no stop condition.
The following code may be helpful to you:
I2C0_ADDRCFG.B.SOPE = 0;
retVal = I2c_SyncWrite(ChannelId, Buffer, I2C_SIZE_1_BYTE, SlaveAddress);
I2C0_ADDRCFG.B.SOPE = 1;
retVal = I2c_SyncRead(ChannelId, ReadBuffer, I2C_SIZE_1_BYTE, SlaveAddress);
samcs
The format is as below
samcs
is the SOPE only working for I2c_SyncWrite()/Read(), not for I2c_AsyncWrite()/Read()?
Do you know how to implement the Restart with I2c_AsyncWrite()/Read()?
Nambi
hellopanda
First question asked 5 sign-ins First solution authored
What is the final answer? The other thread does not seem to have a verified answer. Which one should i refer to?
Nambi
You can check the comment on  ‎Sep 05, 2023.
Best Regards.
