Jony1211
10 replies posted 25 sign-ins 5 replies posted
When I was developing the product, I used the XC2267 chip to perform two reads and writes every time I read peripheral register data. The waveform of IIC communication is not a problem, and I don't know where the problem lies. Is there a reference to the IIC read and write related routines for this chip
Kevin_Wu
100 sign-ins 50 replies posted 10 likes received
Hi Jony1211,
  Through DAVE configuration, you can generate code without FIFO and without interrupt.
 first step: follow the instruction, select USIC channel, master mode, PINs and baud rate;
 second step: not select FIFO with 0;
Third step:  goto functions tab, select 3 items below.
after the code generation, you will get initiation, readData and writeData functions.
thanks, Kevin
Hello, is there an IIC read and write routine for XC2267M?
Read through IIC, not FIFO, my problem is that I need to read twice when I read in IIC, I want to solve this problem, this is my code.
In the U0C1_IIC_vMasterReceive() function, if the receive function I configured with Dave is not changed to U0C1_IIC_vWriteData(U0C1TDF_MRStart, uwDeviceAddrU0C1 + U0C1IIC_READ), I can't even read it.
Attached is my IIC communication section.
Kevin_Wu
Hi Jony1211,
thanks, Kevin
