I am running vector autosar on tc399. I found that the csa ram space is full of 0x00 and there is no callstack information. Do I need to do anything to enable it?
SuperDan
First question asked Welcome!
oldPcSpeakers
Level 4
Level 4
25 replies posted 5 likes given 5 solutions authored
In general I would suggest to check if your application is correctly built and if you initialize device correctly in your application. Maybe get some prebuilt example that works to see how it looks like and compare it to your own.
Jeremy_Z
1000 replies posted 250 sign-ins 100 likes received
Hi @SuperDan ,
I was wondering if you could indicate the timepoint that the CSA space becomes the 0x00, as the CSA space should be initialized before jumping to application SW.
BR,
Jeremy
